Can infographic get median instead of sum of data from multiple polygons?
834
07-30-2024 05:55 AM
rp23
In my Experience Builder project I have an infographic that uses custom variables. The variables are percentages, so when multiple polygons (zip codes) are selected I would like the median value to be displayed in the infographic. Currently the sum of the areas is displayed.
The variable fields are "double" type. I've tried changing them to integer and tried Field Value Type as "Percentage or Ratio", "Measurement", and "Count or Amount". The result is always a sum.
Is it possible to display as median instead of sum?
FasilTiru
Hello @rp23,
I recommend posting any questions related to the Business Analyst products here for more visibility by our team: https://community.esri.com/t5/arcgis-business-analyst/ct-p/arcgis-business-analyst
If you are using variables from your custom data setup in the infographic, please note that the two data summary options available are "Sum" and "Average" as shown below:
Learn more about custom data setup: https://doc.arcgis.com/en/business-analyst/web/custom-data-setup.htm
Fasil T.
Business Analyst Team
Ke_Xu
by Esri Regular Contributor
hi @rp23 , which widget are you using in Experience Builder? Infographic widget?
Ke
rp23
Hi, I'm using Business Analyst widget. Thanks
Wei_Ying
@Fasil could you help with this question related to Business Analyst widget? Thank you!
FasilTiru
Hello @rp23,
Fasil T.
