Can I customize the search tool text color in LIST widget?
1036
12-16-2024 03:21 PM
DaisybLewis
I am building an app using Experience Builder. I added the list widget to display my data and toggled the search tool to be enabled. The color of the search tool text defaults to this light grey color. The main theme color of my app is this blue that you see in the image below (brand requirement color), which contrasts quite horribly with the default search text color (I can barely read the text).  I've changed every color in the theme and used every template, but the color of that text in particular will not change. Am I missing something, or is it not configurable? Thanks in advance!
Amarz
Not sure if its possible, but if it is, try the advanced formatting. Here is a link to each of the formatting parameters.
https://doc.arcgis.com/en/dashboards/latest/create-and-share/advanced-formatting.htm
LaurenCardona
Hi, did you find a solution to this? I am currently having the same problem.
JohnMoore12
This is a nice feature to have, currently the items in my list widget searches are near unreadable.
ShengdiZhang
The list widget supports setting foreground color in the October 2025 AGOL release. However, this setting is only available in the new theme.
Shengdi
