Can Feautre Info show the same records as selected in the Popup?
953
03-11-2025 01:26 AM
Labels (2)
Cory__Williams
Hi @Jianxia ,
the enhancements to the Feature Info panel have come a long way, but I feel that it's still missing in a few areas which I'm hoping may be coming?
When using Interact with a Map widget... If we select a feature on a map and there are 3 records associated to a specific layer, at the moment, the Feature Info panel doesn't honour that, instead shows that one record but then allows us to scroll through the remaining records (sometimes in the thousands).
We get the same issues with the Select Data function.
If we use Select Data and optionally choose to show only selected records, because we are not using the Select tool nor the Query tool, it will only show the first record and not give us the options to scroll through other records.
Are there any plans to allow the Feature Info panel, to work similarly to the feature popup, so that we will only see the layers that are intersecting that the point which we have clicked?
Also, if this were able to be done, having the ability to list the number of records against the dropdown of features (and optionally hiding those that have 0 records returned) would be advantageous!
JamesBeamish
Great suggestions - My users would benefit from these changes as well.
Wei_Ying
Hi, yes we do have a plan to enhance the FeatureInfo UX to more like popup experience.
It is on our 2026 roadmap. Thanks!
