I am using a Near Me widget to search crimes at location drawn on the map.
I also have a filter setup to filter the crimes.
If I perform a location search using the Near Me widget and then change the filter values, the Near Me widget does not automatically filter its results to reflect the filter change. If I manually refresh the Near Me widget results, they get filtered accordingly. But I need them to filter automatically.
This only happens if the Near Me widget Results are configured to "Filter Layers to only show results". If that check box is not checked, then it works as expected.
The Filter widget has an Action configured to let the Near Me widget know that the filter has changed. The Action is configured like this:
- "Data filtering changes"
- Target data is the layer that the filter filters
- Action data is the output result layer from the Near Me widget
Not sure if this is a but or by design, or I am just missing something.
Any advice is greatly appreciated. Thank you!
Filter Widget Action configuration
