ArcGIS Dashboards SVG icon libary in Experience Builder
3829
09-05-2023 01:22 PM
JonathanLee
Is there a way to use the ArcGIS Dashboards SVG icon library in Experience Builder? I'd like to re-create some dashboards in Experience Builder but one thing that I can't find in Experience Builder are the nifty icons you can put next to indicators in Dashboards.
jcarlson
You can go to https://www.arcgis.com/apps/dashboards/assets/ui/esri-icons.svg to get all the SVGs in one place, then just use something like Inkscape to pull out the individual icons you want to use. Still not an "easy" way to get those icons into the various icon pickers in the EB interface, but at least you'd have them.
- Josh Carlson
Kendall County GIS
JonathanLee
Thanks @jcarlson! For some reason that link you provided isn't loading. And I've tried googling for a library of their dashboard icons but can't find them either.
jcarlson
Oh, it's loading! It may look like a blank page, but if you view the page source, you'll see the icon code.
- Josh Carlson
Kendall County GIS
JonathanLee
Oh, excellent! Thanks!
JonathanLee
My workaround so far:
  1. Go to https://www.arcgis.com/apps/dashboards/assets/ui/esri-icons.svg
  2. View page source
  3. Copy <path> tag for the desired icon
  4. Paste into Notepad within an <svg> tag
  5. Save the .txt file as an .svg
  6. Open the .svg file in Illustator
  7. Export the .svg file from Illustrator as a .png (.svg files are no longer supported in the Image widget in Experience Builder).
Not the most convenient method but it works (so far).
