Allow users to change Symbology field in Experience Builder
3328
04-25-2024 10:28 PM
Labels (2)
PurakShrestha
Hi
I have a a feature layer with many fields in Experience Builder.
I would like the user to be able to select the field that the map symbology will be based on, a bit like changing Symbology field in ArcGIS Pro. And I need the symbology type to be Graduated.
Is there a widget that can do this or would it need to be a custom solution? If custom, can you point me in the right direction.
Kind regards
JeffreyThompson2
MVP Frequent Contributor
There are no options within Experience Builder that allows the end-user to change symbology. You will need to make a custom widget.
Custom widgets in Experience Builder do have access to the full power of the Javascript API. This page is a good place to start learning about variable symbology in the API.
GIS Developer
City of Arlington, Texas
