AGOL update yesterday broke the zoom to on my search widget
3286
27
10-23-2025 08:48 AM
JamesBurton1
I'm using the Search widget in Experience Builder on one of our heavily used applications. After yesterdays update, the "zoom to" aspect of the search bar is broken. Instead of zooming to the address point, it takes us across the world to Europe.
Anyone else having this issue?
All I can think to do is turn off the zoom to option. But that doesn't resolve the issue.
2 Solutions
MathiasHudock
This helped in my case; I was able to switch from "Add custom search sources" to "Interact with a Map widget", and then use the "Custom search sources" option to add the same sources my organization was previously using. Search bars worked fine after that.
ShengdiZhang
This bug should be fixed in today's update. Please let me know if you can still reproduce it.
Shengdi
DavidColey
MVP Frequent Contributor
Not yet, but is this happening for a layer search, the world geolocator service, a local geolocator service, all three?
JudithWammack
@DavidColey  that I have notice layer search. I do not use the geolocator services.
gallatingis
Yep, update broke something for sure.  Just got a minifield React error #185 using search on our public facing map.
Edit: FYI, layer search, using 9 layers.  If we drop the # of layers searched down to 4 or 5, functionality seems OK.  Never had a problem until this morning.
JudithWammack
@gallatingis One of my application search through 4 layers. It isn't as noticeable but it still happens.
JudithWammack
I have an open case with ESRI as well. Waiting for a phone call. Glad to know I am not the only one.
JudithWammack
Previous Functionality:
  1. The user searches by address, parcel number, or name.
  2. The user selects the desired record from the search results.
  3. The Search Widget automatically zooms to the selected result.
Current Behavior (Post-Update):
  2. The user selects the desired record.
  3. The widget briefly and automatically selects a random record from our database and zooms to that incorrect location.
  4. Almost immediately after, it then displays the correct record, but requires the user to click again to finalize the selection.
This is the full issue my zoom is having.
StephanieW
Hi @JamesBurton1 Do you have any records in the are that Experience Builder is incorrectly zooming to? Your description and @JudithWammack 's sound very similar if so. If not I would advise creating a support case if you are able to so we can help investigate the app and data closer. https://support.esri.com/en-us/contact
JudithWammack
@StephanieW I already have a case open with ESRI.
DavidColey
@JamesBurton1 @JudithWammack - are your search widget settings set to 'Interact with a map widget' or 'Add custom search sources'.  All of mine are set with 'Add custom search sources' and then the zoom and pans are by trigger action.  I ask because I am not seeing any zoom pan issues, but I don't have anything set to interact with map widget
