Add Map Scale Text to Dynamically Display Scale
1586
03-14-2025 12:12 PM
CameronLacelle
Is there a way to display scale text for an Experience Builder map? In the Map Widget options you can display a scale bar but not associated scale text (i.e. 1:100). I tried looking at the Text Widget a bit to see if I could write any dynamic arcade code or anything to display the current map scale with no luck. I am using Enterprise 11.3 version of Experience Builder
Ke_Xu
by Esri Regular Contributor
Hi @CameronLacelle,
The current feature is not supported; it is planned, and you can track this case.
ENH-000147684 Request to allow choices between units, intervals and styles when we toggle on the scale bar option in the Map Widget in Experience Builder
Ke
Ke_Xu
Hi @CameronLacelle,
This feature has been released on ArcGIS Online in October 2025.
CameronLacelle
@Ke_Xu Good to know. So is this feature available in ArcGIS Enterprise 11.5 too? We work with Enterprise mostly and will be upgrading to 11.5 soon.
Ke_Xu
@CameronLacelle, This new feature will be available with ArcGIS Enterprise 12.1.
