2025 Q1 Update: Chart Widgets Crashing When Using the Filter Widget
816
02-27-2025 11:56 AM
SidneyMechling
I am having issues with the chart widgets after the newest update. When I go to filter my data set using the filter widget, the chart crashes and says 'Error Failed to fetch dynamically imported module: (link)'
This is a major issue as I use these charts to develop reports and always filter my data. This seems to be linked with the new update.
SidneyMechling
I just received an update from esri support that the bug has been fixed. This issue only occurred with numeric filters. I tested all of my charts this morning and they are back up and running correctly!
Stephanie_F
Hi @SidneyMechling I suggest logging an Esri Support case if you are able to so they can investigate deeper with info about your chart configuration. https://support.esri.com/en-us/contact
JunshanLiu
@SidneyMechling We can't reproduce the issue, is there a reproducible app?
SidneyMechling
