Name of the bookmarks in the Experience Builder Bookmark widget have capital letters on each words, and do not follow the way it is written in the configuration window for the widget (see attached image). Is this a bug? This is so meaningless and it looks very stupid.
Hope Esri will fix this soon!
If you select one of the Advanced templates you should be able to design and name your bookmarks however you wish.
Thanks @JeffreyThompson2 . This workaround will work but it is quite some more work to set up (rewrite the names, add images manually).
Issue as been fixed in the june update 😀
Sign in to post, follow content, and more. New here? Register for free.
