What's new in Near Me in Experience Builder in November 2024 ArcGIS Online update
1033
11-05-2024 10:06 AM
AzizaParveen1
New features added in Near Me for November 2024 release,
New functionalities:
  • Added support for Subtype group layer data
  • Added support to view related records
  • Added a loading icon that is interactive so user can cancel out analysis process when analysis process takes longer.
  • Support data actions at the selected feature level(Zoom to, Pan to, Show on map, Set location and Plan route when Direction widget is configured).
WAB functional parities:
  • Automatically update results based on map area extent. This functionality works with Map widget's Extent change -> Filter data record message action and Near Me's Current map area search method, when these are configured, Near Me will automatically update results with extent change. Another suggestion in this scenario is, please enable client side query in the Map widget for better performance.
  • Show results on map for all configured layers regardless of their visibility status (added new configuration parameter in the Results section)
  • Near me to return only intersected features (configuration parameter that will only available for polygon features when configuring Closest or Proximity analysis)
  • Add support to use Near Me result as input location (configuration parameter added in the results section)
2 Comments
