We only have few updates for Near Me in October 2025
New features:
Near Me now supports current location as input:
You can use the Map widget's Locate tool to set your current location as the input location for the Near Me widget. To do this, add the Location change trigger in Map widget settings, choose a Near Me widget as the target, then select the Set location message action.
Added support to clip features:
We have added a new setting in Near Me Proximity analysis to clip intersected features. This setting will only show up for line and polygon features when you configure Proximity analysis. When enabled, it will return intersected length or area of the proximity features by the input feature or input feature search area.
The clipped area or length will also be included in the exported PDF report and other exported format when export is supported in the layer.
Existing setting move:
Feature count setting is moved to Edit analysis panel, showing feature count could be controlled at layer level.
