Generating report from Near Me in Experience Builder is available now with Enterprise custom print service
4032
11
06-06-2024 08:19 AM
AzizaParveen1
We are regularly adding new functionalities in Near Me widget in Experience Builder to achieve the same level of functionality as the Near Me, Info Summary, Screening, and Situation Awareness widgets in Web AppBuilder, With ArcGIS Online February update and Enterprise 11.3 release, we added support to generate dynamic reports from Near Me results from Print widget in Experience Builder.
Known Limitation:
  • Right now it only works with Enterprise 11.3 print service and it is not supported in ArcGIS Online print service.  If you have enterprise environment you can publish your custom print service with reporting capability, share the service with everyone and use it in the online environment.
Requirements
  • This feature requires a custom print service published or a portal item with reporting templates in Enterprise 11.3,
  • Report schema needs to be same as the output data schema from Near Me.
How to create, publish and consume custom print service:
Please follow these blogs and doc to create, publish and consume print service with reporting capability.
11 Comments
