What is the max length of a long lived token for portal?
2443
08-24-2023 01:03 PM
MichaelBishopp
I am trying to determine if I can set the life of a long-lived token beyond the 14 day limit.  It seems like I cannot, even if I set the token length in /server/manager to much more than 14 days.  Is this possible?  What is the maximum length of a long-lived token?
Tags (3)
jill_es
@Raul_Jimenez, thanks for looping me in here!
@MichaelBishopp, you are correct - the maximum life of a long-lived token in Enterprise is 14 days.  As you mentioned, with Enterprise you'll be using the Enterprise portal tokens as ArcGIS Server is federated and using the Enterprise portal identity store.
MichaelBishopp
MichaelBishopp
All ArcGIS Servers are federated with Portal, so I assume I need/can use a portal token.
Raul_Jimenez
Hi @MichaelBishopp !,
Thanks for your question!
Considering this is about Portal I'm going to move it to ArcGIS Enterprise Service Questions. And let me cc: @jill_es which I'm sure will be able to help you 😊
jill_es
