Saving measures as drawings may be misleading
793
01-24-2023 12:56 PM
GeoffroyRicher-Lalonde
When a user makes a measure (Point, Line, Path, Circle or Polygon) and saves it as a drawing, some information get written in the <description> element of the KML. Examples :
  • A Point will record the Latitude, Longitude and Elevation
  • A Line will record the Distance and Heading
  • And so on...
It may be useful at first hand. But when the drawing is edited afterward, the information of the <description> becomes obsolete and misleading :
Could the information of the <description> be updated with the edits? It would be great. If not, I suggest that no information should be stored when a measure is saved in the first place.
Thank you.
Geoffroy Richer-Lalonde
GIS Specialist, Hydro-Québec
LexieLi
Hi @GeoffroyRicher-Lalonde ,
We notice that you frequently give us good suggestions, which are much appreciated!
We have recorded your suggestions and will keep you posted if there are any updates.
Lexie
