Hi all
I tried to load TPK in geo wgs1984 projection (after I change the spatial reference in setting) and fail.
I opened a call nad got bug BUG-000115105.
It looks like very basic functionality.
Anybody out there is doing this?
Hi Mody,
The LOD of TPK with WGS84 GCS coordinates you provided is different with Earth requirement. Since Earth is a globe we require the first LOD is half of globe. So the first LOD resolution should be 180 / TileCols = 0.703125.
I have uploaded an XML file with WGS84 GCS coordinates in conf_WGS84_512.xml and the shared TPK with this XML works well in my side.
Hope it's helpful.
Xuewen
It should work for WGS84. I'll check your issue BUG-000115105.
Thanks.
Hi Yongwei
I got some response that the tpk should be build until scale of 300M or so.
I tried this but still gets an error that the schema does not match.
If you can find a schema (XML file for the GP that create the cache) that will make it work it will be great.
Hi Xuewen
It is working, many thanks.
Is this documents any where or is there a way to find out about this?
I still have a few questions:
1) Do you have to go to level 147M even if your tpk is 10X10 kilometer?
2) Can I create levels below 4500 (2250, 1124, etc) - do I just divide by 2
3) Is there any limitations about the format (JPEG) and the quality (65)
Thanks again
Mody
