Filtering Issue - when building with "contains", ArcGIS Earth will fill in a full value from the drop down
782
08-19-2025 10:11 AM
JessicaSmucker1
When building an expression in ArcGIS earth with multiple lines, the first "contains" gets filled in with a value from the dropdown.
YujingChang
Thank you for reporting this issue. We were unable to reproduce this behavior on our side. Could you please provide more details, such as the exact steps to reproduce it or screenshots? This will help us investigate further.
JessicaSmucker1
Hi! Yes - I just encountered the issue again. It occurs when I want to use "contains" and fills in a value from the dropdown. When I change it back from "ABC DEF" to just "ABC" for example, it will change it back to "ABC DEF" since it matches a dropdown value.
