Unable to connect to database list......
14242
29
07-28-2014 11:25 AM
ChadFoster
ArcGIS 10.1, SP1, Build 3143
ArcGIS Server 10.1
I installed ArcGIS on several new computers in a training lab for our county, I also installed all the SP's, patches and SQL Native Client files.  This is the same installation as my desktop.  When I log in to this computer with my existing username and password, go to ArcCatalog and try to set up a connection to SDE, I get the following error.
Does anyone have any suggestions?
Chad
AsrujitSengupta
So, the problem is occurring from only one machine? The connections work fine from your personal desktop machine?
Try to copy the sde connection file from that working machine to this problematic machine and then try connecting.
ChadFoster
The problem is occurring from 4 machines located in one of our training centers.  The connections work fine from my desktop and the desktops of my other 4 coworkers.
AsrujitSengupta
If you have SQL Server management Studio installed on any of those 4 problematic machines.....are you able to connect from there to this instance?
ChadFoster
I don't have SQL Server Management installed on any of these machines, nor do I have SQL Server Management installed on my normal desktop.
JacobBoyle
have you tryed to just ping the host server from command line on the pc and see if they can even contact the SQL server?
in CMD.exe type ping <servername>
ChadFoster
yes I can ping the server.
JacobBoyle
OK, that's a good start!
are you running the most current version of SQL Server Native Client on all the machines?  Is it the right version for the OS?
ChadFoster
Yes and yes, it the same instillation process as my desktop, same operating system, same SQL Server Native client.
JacobBoyle
On a machine with good connections to SDE browse to: C:\Users\<your user>\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog.  You may have to unhide the folder: Show hidden files - Windows Help
Copy anything with a .sde and paste it to the same folder on the new machine.
ChadFoster
Jacob,
That worked!   I guess now I have to copy those files to the other three computers under the folders for those users.
Do you think I will have to do that for every user that logs onto one of these machines?
