Symbols not showing Correctly.
12133
11
09-30-2014 02:30 PM
GaryFields
ArcGIS Desktop symbols not showing correctly after new install on a Win 7, 64 bit desktop.  Anyone else run into this?
V_StuartFoote
Gary Fields‌, *,
ArcGIS Symbols are defined making use of installed fonts. If the installation was complete, you will have TrueType font libraries TTF installed into C:\Windows\Fonts directory.
For ArcGIS 10.x should be 73 named esri_1.ttf --> esri_837.ttf.  These font/symbol libraries will have a Title associated with them, e.g. esri_1.tif is Titled: ESRI Cartography  and esri_837.ttf is Titled: ESRI ERS Operations S1.
If they are missing, or can't be read the system will substitute a replacement from an available font/symbol library on the system.  A common one that causes issues for folks is the esri_40.ttf library titled: ESRI North--those are the North arrow symbols that don't exist on most systems and sometime are not embedded into PDF printouts from ArcMap -- the arrow is missing and a weird character is shown instead.
So, take a moment to look in C:\Windows\Fonts and check that the ESRI fonts are present, and also that in the Properties --> Security tab Users are able to Read & Execute, and Read the fonts/symbols. Be sure to check a few of them.  If not present, try the repair install. If present and incorrect permissions, should be able to assign correctly (or rerun the installation "Run as Administrator").
Stuart
Edit note: adjusted first sentence--symbols are defined making use of installed fonts, rather than symbols are installed as fonts. They aren't but they need the fonts available to structure the symbols.
GaryFields
Thanks, that was it!  ESRI fonts were not working correctly, copied from my install and replaced.
