Serving 9.x AND 10.x licenses
7317
11
05-10-2010 08:31 AM
curtvprice
We (like many others I'm sure) would like to serve 9.x AND 10.x licenses for a while. Can they be served from the same license manager, or do we have to run parallel license managers at once using different ports?
BadrinarayanaLakkur
The 10.x licenses and license manager will support 9.x Desktop and Workstation software.  The 9.x and 10.x license managers cannot be installed on the same machine.
curtvprice
Badri, this sounds fantastic, however it is not working for us. (We're using 9.3.1sp1 client, 10.0 PR1 license server).
When I use the 9.3.1 license manager and point to the 10.x license serve,r I get this message:
The computer you chose is not a valid license server or is running and older version of the License Manager.
Are we going to need new 10.x-style 9.x keycodes to do this?
BillyBuerger
I'm using our V10 licenses from my 9.3.1 SP1 PC right now.  I'm trying to remember if I had problems with it at first.  I almost want to say I had to manually set the server in Regedit initially.  Although I can change it now and don't get any errors.  So I might just be remembering something else.  The Availability section says there are none available.  But it still correctly retrieves a license when I open ArcMap.
Your error sounds more like it's not able to access the license server at all.  Have you tried from a separate PC running Arc10 to see if it's an access problem versus a license problem?  Can you ping the server?  Is the firewall correctly opened up?
curtvprice
Thanks for sharing your experience - I think this was a firewall issue. I have tested 9.3.1 client on the same machine as a 10.x license server and it works - just like Billy reports - with Desktop Admin's Availability report saying zero licenses available, without any extensions listed.
UPDATE: I learned a fix for this will be included in ArcGIS 9.3.1 SP 2 -- so Desktop Administrator will "see" license availablity on a 10.x license server. Yay!
If you're on a 9.3.1 machine, there is a workaround to check availbility, even if the the 9.3.1 client can't talk to the new license server: get a copy of the new 10.x lmutil and run
lmutil -a -c @my_arc10_license_server
and you get the details:
lmutil - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
Flexible License Manager status on Tue 5/11/2010 11:08
License server status: 27000@localhost
    License file(s) on localhost: D:\ArcGIS\License10.0\bin\service.txt:
 localhost: license server UP v11.6
Vendor daemon status (on igskmccwws039):
    ARCGIS: UP v11.6
Feature usage info:
Users of ACT:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of ARC/INFO:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of ArcScan:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of GeoStats:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of Grid:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of Maplex:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of Network:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of Publisher:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of Schematics:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of TIN:  (Total of 6 licenses issued;  Total of 0 licenses in use)
BillyBuerger
Glad to hear it's working.  I've been playing around with the new lmutil myself.  Hopefully they'll give some documentation on the changes as I'm having troubles getting lmremove to work and think that this ACT thing has something to do with it.  But I haven't been able to find anything about it.
AngelaO_Neal
I have users pointing to a 10.x license server with 9.3.1 machines, and they seem to run fine but there is no server info in the Desktop Administrator.  Are there any other issues besides this we need to worry about with this scenario, as long as 9.3.1 runs OK?  They have indicated having issues with 9.3.1 SP2, so they don't want to update to that to fix this issue.
Just want to make double-sure.  Thank you!  Amy
V_StuartFoote
The new ArcGIS 10.x LM serves license authorizations to ArcGIS 9.x clients.
No issues other than an ArcGIS 9.3.1 client can not be served Bing Maps/Virtual Earth license authorizations via an ArcGIS 10.x LM, so if continued 9.3.1 use of Bing Maps is an issue--retain an ArcGIS 9.x LM as an alternate license pool.
Once installed, the ArcGIS 9.3.1 SP2 does resolve Desktop Administrator issues when polling the ArcGIS 10.x LM. But as you mention some folks have had problems with the download and installation. But, that was not our experience and may just have been load on ESRI's download servers when the patches were first released.
Stuart
KateBuss
I also need to serve up both 9.3 and 10 licenses from the 10 License Manager. But according to ESRI's web HELP v10 it says - "License files at version 9 or earlier will not work with this new version of the License Manager. You will need to first authorize licenses on the license server using the new authorization information sent via e-mail by ESRI Customer Service before starting the license service."
I have all my 9x license files but how do I go about getting new license files for my 9.3 software that work with the 10 License Manager?
The customer care portal seems to only generate version 10 licenses.
Any help would be appreciated!
KateBuss
Figured this out myself.....But for those of you who want a simply summary on how to do this...here goes:
First, make sure your Esri Global ID account is associated with your customer number.
Go to Esri's new customer care portal - https://customers.esri.com/
Generate one provisioning file (email/download) with all the concurrent use software you want served up by the license manager. This will be a .prvs file. (For example 3 ArcInfo, 2 ArcView, 1 3D analyst - whatever you're paying maintenance on will show up on your Authorization Summary).
Next, uninstall your 9.3 License Manager.
Next, install the 10 License Manager from your ArcGIS Desktop CD. At the end of the install you will have the option to authorize your software (as normal). In the authorization wizard - Select the option 'I have received an authorization file from ESRI and am now ready to finish the authorization process'.
Browse to the saved provisioning file.
Select 'Authorize with ESRI now over the Internet'. (Select the website or email option if your machine does not have an internet connection.)
Review the pre-populated information and enter any additional information required. Next, you will see the authorization numbers entered for the desktop products and extensions - as well as the number of licenses you have of each product.
Click Finish and you're done! Your 9.3 clients will be able to read the 10 License Manager no problem.
A side note on provisioning files...I think many people will be easily confused and think that a provisioning file is a license file. However, it is not. All the provisioning file is is a text file that prepopulates user information and product registration numbers into the License Authorization Wizard. It saves you from having hand enter your contact info and reg numbers. This is certainly helpful if you have lots of software or single-use installs. If you choose the "Authorize by email option" - you can still obtain actual license files as many people are accustomed to doing.
The major difference at Version 10 is that Esri is tracking when you authorize a piece of software via the Customer Care Portal. Every time you authorize a piece of software, the number of available authorizations decreases. This obviously prevents people from illegally installing one copy of the software on multiple machines.
Anyway...hope this helps someone.
