"There was an error in the XSLT File" - Metadata View
649
07-14-2017 01:53 PM
AdamChow
Hello everyone,
I am having an issue in both Arcmap 10.2.2 and ArcCatalog when trying to view metadata for featureclasses. When I click on the "Description" tab in ArcCatalog I receive the error "There was an error in the XSLT file. Configuration system failed to initialize."
I tried the following solutions:
1. Repair install of ArcGIS
2. Delete config file in C:\Users\USER\AppData\Local\ESRI\DefaultDomain_Path_eobgy3gnudg2yotqmwb0iplljsghcsqc\10.2.2.3552
3. Copied the contents of C:\Program Files (x86)\ArcGIS\Desktop10.2\Metadata\Stylesheets  from another user who doesn't have the issue.
My last solution would be to do a clean re-install, however, I have a lot of extensions and add-ons that are a pain to configure and I rather not perform this solution.
Any help is greatly appreciated!
