ArcSDE from ArcGIS Server and from ArcGIS Desktop difference
6820
6
10-13-2014 10:58 PM
juan_marvinwirjomartono
Dear all,
I would like to know what is the difference between ArcSDE that comes from ArcGIS Server bundle and the one that comes from the ArcGIS Desktop suite? Now I have the ArcSDE for Microsoft SQL Server 10.2.2 (that comes from ArcGIS Server) and ArcSDE for Microsoft SQL Server Express (Personal) (that comes from ArcGIS Desktop). Is the function different? What is the different in purpose and target between those two ArcSDEs?
Robert_LeClair
Esri Esteemed Contributor
In my classes, I break it down this way:
Desktop SDE - comes with a Standard or Advanced license (Desktop), uses SQL Server Express, administered in Catalog or ArcCatalog, only works on Windows OS, total DB size:  10 GB, 3 concurrent users, only 1 can be editing at any given time.
Workgroup SDE:  comes with ArcGIS for Server purchase, uses SQL Server Express, administered in Catalog or ArcCatalog, only works on Windows OS, total DB size:  10 GB, 10 concurrent users, all of whom can be editing at any given time.
Enterprise SDE:  comes with ArcGIS for Server purchase, uses SQL Server/Oracle/DB2/Informix/PostgreSQL/Azure/others, requires DBA for database administration, works on Window/Linux, Unix, total DB size:  unlimited, unlimited connections
There's more certainly but this should help clarify.  Let me know if you have further questions.
Regards,
Robert LeClairEsri-Denver
Pieter_Geertvan_den_Beukel
for the difference between those 2 versions, please read this link under 'Capacity.
AsrujitSengupta
Yes, they are different and for different purpose.
Geodatabase | Multiuser Geodatabase
In the above link, assume the below:
ArcSDE for Microsoft SQL Server 10.2.2:                SDE Enterprise
ArcSDE for Microsoft SQL Server Express (Workgroup): SDE Workgroup
ArcSDE for Microsoft SQL Server Express (Personal):      SDE Desktop
Robert_LeClair
Regards,
EverardoBalboa
Good morning Robert, I am new to the SDE function.  I have no experience in setting up the ArcSDE in any plat form.  Can you guide me int he right direction on How to use the SDE Function in ArcGIS 10.2 for Deskstop.  I have the Advance License.
Thank You
Sincerely,
Everardo Balboa
Robert_LeClair
Everardo - best place to start is the Help - basically you'll need to install SQL Server Express 2008 R2 or 2012 first.  The ArcSDE business logic is built into the Desktop application.  From there you can create a Desktop SDE geodatabase with all the limitations I mentioned in an earlier post.  Good luck!
Regards,
Robert
Thank you all. I get the picture now.
