ArcGIS Desktop 10.4 - The search window has disappeared
16276
21
03-30-2016 12:46 AM
SteeveEbener
Hi all,
I am posting my issue here as I could not find another group where to post issues related to ArcGIs desktop.
I have recently installed version 10.4 on my computer and after opening ArcMap few times the search window has simply disappeared. Clicking on the icon or on Windows>Search does not make it come back.
I have tried several things including uninstalling and reinstalling, repairing, changing the name of the normal template (normal.mxt) to get a new one being created...nothing works..
Any insight would be very much appreciated.
Thanks in advance,
Steeve
SteeveEbener
Hi Mayur,
Sorry to hear you are facing the same issue.
I had to re-install ArcGIS 10 for another reason and the re-install solved the problem.
I am afraid this might be the only solution at this stage.
I hope this is useful.
Cheers,
DanPatterson_Retired
Is the whole Contents window gone? if it is, it should appear to the extreme right of where it is supposed to be.,
If Contents, doesn't appear select the View tab and select Contents
SteeveEbener
Hi Dan, thanks for the comment.
The all window is gone and not appearing anywhere on the screen.
go to the task bar at the bottom of the monitot right-click and select show windows stacked select it and drag it on screen
the View tab...Content should have search
SteeveEbener
Still not appearing...this is really strange
If this doesn't appear, it is off screen, so try one of the taskbar options like I suggested.
curtvprice
That screenshot is Pro isn't it?
yup...only took a week for someone to figure out I had the right screen grab for the wrong question.... or vice versa .... I will just leave it... might come in handy sometime
JoshuaPrescott
Have you discovered the reason or solution for this issue yet?  I am having the same issue.  I tried the suggested solutions from the responses to your post, but they didn't work.
SteeveEbener
Hi Joshua. I am unfortunately still struggling with it as well in ArcGIS 10.4 (ArcGIS Pro is fine).
