Re: ArcGIS Data Reviewer Roadmap (January 2024)
1082
7
01-08-2025 04:28 AM
Naveen_dd
Is there any file of Data reviewer rules to import?
How can we generate the report using DR?
JayCary
Can you provide some additional details/background on what you are hoping to implement using Data Reviewer?
Naveen_dd
1. I am using ArcGIS Pro 3.3. we have our schema while getting data from delivery partners need to
1. Check geometry (null etc) projection system etc.
2. Data compare with our schema so can find the missing FC's
3. Major Topological checks (identical, overlap)
4. Able to find number of Dataset FC and count
5. if possible, can check some major attributes populated or not.
we have data reviewer extension as well but not able to use much except topological checks.
in short need to review the data and can send back to partners with error report.
any help will be greatly Appreciated!...
JayCary
@Naveen_dd wrote:
  • Items 1 , 3 and 5 should be achievable using Data Reviewer's checks implemented as a validation attribute rule. Suggest investigating use of the following checks:
  • Item 2 is on the product roadmap for a future release. Please take a moment and add your feedback and kudo.jpg on this idea post to tell Esri how important this feature is to your organization!
  • Unclear on Item 4. Could you provide some info on item and how you are using it in your workflow?
Naveen_dd
Thanks, Jay, for your response.
point 4 is once we received any GDB, is there any tool to find participating Feature class and their count.
6. another important question is How can we, generate a report of the errors.
please share some link or video by which I can be able to apply data reviewer
JayCary
Point 4:  The Generate Schema Report tool provides a summary count of the objects contained in a geodatabase.
Point 6:  Here's a sample script (blog) for generating an accuracy report based on attribute rule error layers.
Naveen_dd
Hi Jay, pls share some basic steps as I need to run rules like Check Geometry on all feature classes in different Datasets in a file geodatabase. I have Pro3.4 with Data reviewer ext. in my laptop (standalone).
Pls. consider it something Urgent!!
JayCary
See my feedback here.
