AML BatchJob with ReviewerConsole.exe
4439
08-26-2015 08:13 AM
by Anonymous User
Not applicable
I am looking for the batch jobs associated with the AML.
I want to use the ReveiwerConsole.exe with the /pl options. But there is no batch job in the PL.
Do you now which rules can be used for AML production ?
in the directory: C:\Program Files (x86)\ArcGIS\MaritimeCharting\Desktop10.3\Aml there is only schema for AML but no BatchJobs.
If someone has a feedback to share on this
Thanks.
Olivier.
Tags (3)
CraigGreene
In the Product Library window, right click on your production database and select "Choose Data Model Versions"
Check the LBO checkbox in the Choose Data Model Versions dialog.
You should now see the attribute checks available in the Choose Batch Job(s) dialog and window.
Thanks.
CraigGreene
Validation is stored in the Product Library. An AML Product Library can be downloaded from GitHub.
Esri/maritime-product-library-samples · GitHub
Attribute level validation is available.
by Anonymous User
Not applicable
Hi Craig,
Thanks for the PL XML. I had already used this XML for create my Product Library GDB.
I was not very accurate in my last message
With DataReviewer, I follow the steps to validate AML data based on the PL rules.
I got the following:
  • an empty gdb for reviewer workspace (reviewer.gdb)
  • a PL gdb based on the esri templates (pl_aml.gdb)
  • an Production Data gdb with LBO AML features based on the AML_LBO schema (<install_dir>\ArcGIS\MaritimeCharting\Desktop10.3\Aml\Schemas\Workspace\NAUTICAL_LBO_TEMPLATE_GX.XML) (lbo.gdb)
I have already Create a new Nautical Product (not publish). I can view the export aml data into a third party viewer (seemyencs).
Now I want to validate the product with Data Reviewer.
I start a reviewer Session
I define where the jobs are availables
The product library and the production database are defined but I cannot chose a data model and there is no Batch Jobs.
I can't validate with no rule.
I used the PL from github and AML sample data from UKHO.
Did domeone get the same issue ?
Olivier.
CraigGreene
Thanks.
by Anonymous User
Not applicable
Hi Graig,
It solves my issue.
Thanks.
Olivier
