ArcGIS Data Reviewer at the 2026 Esri User Conference
At the 2026 Esri User Conference, discover what’s new with ArcGIS Data Reviewer, including advancements in automated quality control, reduced data management costs, and industry-focused workflows for utility networks and address data. We’ll also preview emerging capabilities, including AI-assisted data quality workflows.…
Configure Ready To Use Rules to use the same error managment lifecycle as Arcade Attribute Rules
Ready To Use rules currently use an error management lifecycle that involves: Review - Correction - Verification. My organisation requires a simpler process whereby once the issue is fixed and rules are re-evaluated, the validation errors are removed. This is how errors created using Arcade Attribute Rules behave. Allowing…
Need some help converting old Geometry on Geometry checks
Hello, I'm trying to convert our old Desktop-based Data Reviewer batch jobs to the newer attribute rules (mostly as validation rules so far). I have numerous checks on various feature classes that used the older Geometry on Geometry check to basically make sure a field in one feature class matched the thing it is sitting…
How to modify the description recorded in the Reviewer Results
While looking for a way to edit or delete the quality review records created in the Reviewer Results window, I found that they can be modified in the REVTABLEMAIN table within the geodatabase that is generated when using the tool. In the same context, I would like to ask whether the review records created in the Error…
Composite Rule Check - Ability to make an 'OR' composite rule
In the current composite rule check, features are flagged if they satisfy all check conditions. It would be great to have the ability to adjust the rule to flag if they satisfy one of the check conditions. For example, I have a lots layer inside a parcel fabric. Lot features must be within a subdivision or a survey…
ArcGIS Data Reviewer at FedGIS 2026
The Esri FedGIS 2026 conference will be held in Washington, DC on Feb 10-11. It is the premier geospatial professional development event for government. Learn more about the event and register for it here. ArcGIS Data Reviewer automates, simplifies, and improves data quality control workflows to enable the delivery of…
Data Reviewer for ArcGIS Server extension required?
I think I know the answer, but I wanted to make sure I wasn't missing anything else in the publishing process since this is my first attempt at publishing a UN... I have published a branch versioned service with the error tables included and Validation checked at publishing. I can Add Error Layers in a map in ArcGIS Pro…
What’s New in ArcGIS Data Reviewer (November 2025)
The release of ArcGIS Data Reviewer at ArcGIS Pro 3.6 and ArcGIS Enterprise 12.0 introduces new automated review workflows for identifying poor-quality features, enhancements to data quality checks, and improved support for visual review workflows. Additionally, this is the final release that supports workflows reliant on…
Attribute Rule Import Fails (FGDB, Pro 3.5.2)
Since updating to ArcPro 3.5.2 we've lost the ability to import existing stored Attribute Rule files to a newly created FGDB. We can copy/paste the same set of rules from FGDB to FGDB. We can apply the same rules as new rules, from scratch, to a FGDB. Those same freshly created rules can be exported without complaint, but…
Webinar Q&A: Automating Comprehensive GIS Data Quality Control
On June 11, 2025, we held a webinar: Automating Comprehensive GIS Data Quality Control. This webinar showcased how you can leverage ArcGIS Data Reviewer to automate workflows to improve data quality, streamline maintenance, and decrease risk for data consumers. Read the Q&A Blog Watch the Recording
Filtering Data Reviewer Errors by Feature Class in ArcGIS Pro
Hi, I’m a long-time ArcMap Data Reviewer user now working with attribute rules and Data Reviewer in ArcGIS Pro. I recently set up several validation checks in Pro to prep external sewer data (from 20+ agencies/cities) for our Utility Network migration. Each agency's data is stored in its own feature dataset inside a file…
ArcGIS Data Reviewer at the 2025 Esri User Conference
Explore the agenda of Data Reviewer at the 2025 Esri User Conference, browse through our session catalogue, schedule a 1:1 meeting with the product team on-site and find out where to locate us in the showcase! Read the blog
What is the difference between Attribute Rules and Data Reviewer?
What is the difference between Attribute Rules and Data Reviewer? I read the following paragraph but I did not understand what the difference is. "Data Reviewer is an integrated capability in attribute rule-based workflows, that provides a library of no-code, ready-to-use checks that identify common errors found in GIS…
What's New in ArcGIS Data Reviewer (May 2025)
The release of ArcGIS Pro 3.5 introduces 28 more Run Data Checks to identify poor-quality features in a simplified ad-hoc workflow. Additionally, the Valency check for attribute rule evaluation ensures specific polyline patterns connect at a point. Read this blog for details on what’s new in the ArcGIS Data Reviewer…
Webinar: Automating Comprehensive GIS Data Quality Control
Are you tired of spending hours manually reviewing data to identify errors? Join us on June 11 at 8:00 am PT for a deep dive into leveraging ArcGIS Data Reviewer to automate quality control workflows that improve data quality, streamline maintenance, and decrease risk for data consumers. Register now
Grouping Reviewer Results table records
In ArcMap, I used to be able to group records in the reviewer table based on multiple fields - https://desktop.arcgis.com/en/arcmap/latest/extensions/data-reviewer/grouping-reviewer-table-records.htm It was easy to click on a column heading, drag it to the top of the table, and have the table grouped according to that…
ArcGIS Pro Data Reviewer for Branch Versioned Service Updates Last Modified Date
Is there any Data Reviewer option for ArcGIS Pro that does not require updates to be made directly on the features in the the Enterprise Geodatabase? For example, in ArcMap, Data Reviewer writes errors to a file geodatabase and has no impact on the data in the Enterprise Geodatabase. We recently migrated from ArcMap 10.8.1…
ArcGIS Data Reviewer at FedGIS 2025
ArcGIS Data Reviewer automates, simplifies, and improves data quality control workflows to enable the delivery of geospatial data you can trust. Use Data Reviewer to lower data management costs and reduce risk in decision-making by detecting, managing, and reporting errors in your data. Join our session at FedGIS to learn…
After running a Reconcile the Validation Status reverts back to "validation required"
In ArcGIS Pro 3.1.4 I have a Feature Service published to Portal (11.1) from a branch versioned database. The feature service has ~70 feature classes, with the majority of feature classes having Validation Attribute Rules. Within a Version on the service, I have run Data Reviewer through the Error Inspector "Evaluate…
Marking Exceptions
Working in Pro 3.4, I have a collection of Attribute Rule Validations. Some, when I "Mark Exception" also automatically update "Error status", "Error phase" & "Correction notes". But there is a set of rules that only "Is exceptions" updates. The only difference I can see between the validations is that the non-updating…
Data reviewer checks in all feature classes in a file geodatabase.
Need to run rules like Check Geometry on all feature classes in different Datasets in a file geodatabase.
Re: ArcGIS Data Reviewer Roadmap (January 2024)
Is there any file of Data reviewer rules to import? How can we generate the report using DR?
Improving Data Quality for Water Utilities: Webinar Q&A
On November 13, 2024, we held a webinar on Improving Data Quality for Water Utilities. We are pleased to provide the eagerly anticipated answers to the questions you asked during the webinar. Read the blog Watch the webinar recording
What's New in ArcGIS Data Reviewer (November 2024)
The release of ArcGIS Pro 3.4 and ArcGIS Enterprise 11.4 introduces new automated review workflows for identifying poor-quality features, enhancements to data quality checks and improved support for visual review workflows. Read this blog for details on what’s new in the ArcGIS Data Reviewer release. Read the blog
Live Webinar: Improving Data Quality for Water Utilities
In today’s rapidly evolving utility landscape, ensuring high-quality data for efficient operations, compliance, and customer satisfaction is essential for water utilities. This webinar delves into the critical role of data quality management in optimizing water utility performance. We will explore best practices for…
