webgis dr utility can be used to create backup for all portal services(dashboard), ArcGIS enterprise i installed on premise
1653
02-16-2022 10:36 PM
Labels (3)
SoniaDas123
Can webgis dr utility utility be used to create backup for all portal services (such as dashboard,layers,webmaps) if ArcGIS enterprise is installed on premise.
Basically in a situation where server crashes, can i create backup so that i need not customize and make dashboards again.
Thank you,
Sonia
Tags (3)
bwilkinson
Good Afternoon Sonia,
The webgisdr utility includes a backup of your Portal items (which includes Dashboards).
The following references will help guide you in setting up a backup and restoring using the utility.
ArcGIS Enterprise backups—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Create an ArcGIS Enterprise backup—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Restore ArcGIS Enterprise—Portal for ArcGIS | Documentation for ArcGIS Enterprise
bwilkinson
SoniaDas123
Thank you
