Way to convert indicator values to whole numbers
876
11-14-2025 05:39 AM
GeorgeJonesRIGOV
Hi all, is there a way to convert these values to show the actual values? thanks GJPipeValueNumbers.png
KenBuja
MVP Esteemed Contributor
In the Indicator tab, turn off the Unit prefix option
Neal_t_k
MVP Regular Contributor
You can use the advance formatting options in dashboards to achieve this.  In the indicator tab select advanced formatting and use the Round() function to only return 2 decimal places for you display text fields:
Text(Round($datapoint.FIELD, 0))
https://developers.arcgis.com/documentation/app-builders/no-code/arcgis-dashboards/calculate-and-for....
edit: read wrong, you want to turn off digit grouping or the unit prefix
KenBuja
GeorgeJonesRIGOV
@KenBuja thank you!
