Using Arcade expressions to format specific values in Dashboard table field
5402
08-24-2023 10:37 PM
JimMiller3
I've been working from both of these helpful posts about using Arcade to format values and cells in dashboard tables.
I've been able to do some things, such as formatting numbers and percentages. But I haven't been able to figure out how to bold specific values in a column and, for other values, change textAlign from left to center.
I can use displayText to make all values bold, or textAlign to make all values center aligned. My goal, though, is to make those changes for just certain values in the column.
Below is my desired output for the "Revenue Source" field. Thank you for any suggestions.
Revenue Source
Personal Income
   Withholding
   Other Pmts
   Refunds
Corporation
   Estimated Pmts
   Other Pmts
All Other Revenue
   Insurance
   Tobacco
   Other
JenniferAcunto
You need to have your arcade statement return HTML that does your desired formatting.
var bld = Concatenate('<strong>'+$datapoint.COUNTRY+'</strong>')
var lft = Concatenate('<div style="text-align: center;">' +$datapoint.COUNTRY+ '</div>')
var blft = Concatenate('<div style="text-align: center;"><strong>' +$datapoint.COUNTRY+ '</strong></div>')
var ctry = When($datapoint.COUNTRY == 'Cameroon', bld, $datapoint.COUNTRY == 'Angola', lft, $datapoint.COUNTRY == 'Ethiopia', blft,$datapoint.COUNTRY )
return {
  cells: {
    ADMIN1: {
      displayText : $datapoint.ADMIN1,
      textColor: '',
      backgroundColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
      iconOutlineColor: ''
    ADMIN2: {
      displayText : $datapoint.ADMIN2,
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
    COUNTRY: {
      displayText : ctry,
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
- Jen
JenniferAcunto
return {
  cells: {
    ADMIN1: {
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
    ADMIN2: {
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
    COUNTRY: {
      displayText : ctry,
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
- Jen
JimMiller3
Thanks - that worked perfectly.
JimMiller3
A follow-up question to the solution above @JenniferAcunto : If I want to also bold the values in the "Actual" and "Forecast" fields that correspond with the bolded values in the "Revenue Source" field, how do I structure the HTML and Arcade expression? I've tried several ways but I'm not getting the desired result
This is my code:
var bld = Concatenate('<strong>'+$datapoint.revenue_source+'</strong>')
var rsrc=When($datapoint.revenue_source == 'Personal Income', bld, $datapoint.revenue_source == 'Corporation',$datapoint.revenue_source == 'Total',$datapoint.revenue_source == 'All Other Revenue'
return {
  cells: {
    revenue_source: {
      displayText : rsrc,
      hoverText: $datapoint.revenue_source,
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
Actual: {
      displayText: Text($datapoint["Actual"], '$#,###; -$#,###'),
      textColor: '',
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
Forecast: {
      displayText: Text($datapoint["Forecast"], '$#,###; -$#,###'),
      textColor: '',
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
This is my desired result. Thank you.
Revenue SourceActualForecast
Personal Income10050
   Withholding2525
   Other Pmts2520
   Refunds505
Corporation200100
   Estimated Pmts10050
   Other Pmts10050
All Other Revenue300500
Total600650
