Using Advanced formatting with a range of values
2145
06-06-2022 04:43 PM
jkeatonthompson
I am using Advanced formatting in ArcGIS Dashboard, however, the data I am trying to display is not displaying in the correct color. Anything over 4 is yellow. How do I create status colors correctly for a range of values in advanced formatting?
var green = '#2e8540'
var yellow = '#fdb81e'
var red = '#981b1e'
if($datapoint["wave_height"] < 4) {
return {
textColor:'#ffffff',
backgroundColor: green,
topText: 'Wave Height',
topTextColor: '',
topTextOutlineColor: '',
topTextMaxSize: 'medium',
middleText: Text($datapoint["wave_height"], '#.# ft'),
middleTextColor: '',
middleTextOutlineColor: '',
middleTextMaxSize: 'medium',
//bottomText: '',
//bottomTextColor: '',
//bottomTextOutlineColor: '',
//bottomTextMaxSize: 'medium',
iconName:'icon1',
iconAlign:'left',
iconColor:'#ffffff',
iconOutlineColor:''
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
else if($datapoint["wave_height"] >= 4) {
return {
backgroundColor: yellow,
topTextColor: '',
//bottomText: '',
iconName:'icon1',
iconAlign:'left',
iconOutlineColor:''
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
else if($datapoint["wave_height"] < 6) {
return {
topTextColor: '',
//bottomText: '',
iconName:'icon1',
iconAlign:'left',
iconOutlineColor:''
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
else if($datapoint["wave_height"] >= 6) {
return {
backgroundColor: red,
topTextColor: '',
//bottomText: '',
iconName:'icon1',
iconAlign:'left',
iconOutlineColor:''
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
else if($datapoint["wave_height"] == 100) {
return {
topTextColor: '',
middleText: 'No data',
//bottomText: '',
iconName:'icon1',
iconAlign:'left',
iconOutlineColor:''
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
JenniferAcunto
Anything greater than 4 is yellow because that is what your second 'section' states should happen. Once it evaluates as true it stops, so 5, 7, 100, etc are all over 4 and therefore true so it stops there and doesn't check to see if it belongs to another color bucket.
If I understand your buckets correctly what you want is:
< 4 = green
>= 4 and <= 6 = yellow*
> 6 = red
*Technically 6 in your example is not assigned a color so I grouped it with the yellows.
You want your expression to match these buckets, so the yellow bucket should have a minimum and maximum value to constrain it. These values should not be included in the other buckets. Remember, any possibly value you may have should evaluate true only once.
I also find it easier to have a single return statement that uses variables:
var bcolor = When($datapoint["wave_height"]  < 4, '#2e8540',
            $datapoint["wave_height"]  >= 4 && $datapoint["wave_height"]  <= 6, '#fdb81e',
            $datapoint["wave_height"]  > 6, '#981b1e', '')
var mtext = When($datapoint["wave_height"]  == 100, '', Text($datapoint["wave_height"] , '#.# ft'))
return {
    //textColor:'',
    backgroundColor:bcolor,
    //topText: '',
    //topTextColor: '',
    //topTextOutlineColor: '',
    //topTextMaxSize: 'medium',
    middleText: mtext,
    middleTextMaxSize: 'large',
    //bottomText: '',
    //iconName:'',
    //iconAlign:'left',
    //iconColor:'',
    //iconOutlineColor:'',
    //noValue:false,
    //attributes: {
      // attribute1: '',
      // attribute2: ''
- Jen
JenniferAcunto
< 4 = green
> 6 = red
return {
    //textColor:'',
    //topText: '',
    //topTextColor: '',
    middleText: mtext,
    //bottomText: '',
    //iconName:'',
    //iconAlign:'left',
    //iconColor:'',
    //noValue:false,
    //attributes: {
      // attribute1: '',
      // attribute2: ''
- Jen
jkeatonthompson
Thanks allot Jennifer! That was extremely helpful and so far all of my indicators have worked successfully.
KenBuja
MVP Esteemed Contributor
You can make the expression simpler. You don't need to check in line 2 whether the value is greater than 4 since that was already done in line 1.
 You could make it even simpler, but it may not be as intuitive
            '#981b1e');
