Set title orientation for x-axis in ArcGIS Dashboard
2073
03-09-2021 07:16 AM
DavidBondy1
Hi all,
I'm using Portal for ArcGIS 10.8 and I'm having an issue with the title orientation where it's showing up vertically on the x-axis. From what I can see, there is no configuration option to change it from vertical to horizontal. I've attached a image showing the issue.
Does anyone know how I can resolve this?
jcarlson
MVP Esteemed Contributor
That seems very strange. Have you tried toggling the chart from horizontal to vertical and back? Or simply refreshing the page?
Assuming the issue persists, you could just put the axis label in as the chart's Description and make the text centered.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
DavidBondy1
Refreshing didn't work but toggling from horizontal to vertical did. Thank you ❤️
JACooper
Same for me. Thanks!
