We have created a web map with a pop-up dialog box that generates a URL that opens a Survey123 survey. That functionality works great. However, when we add the web map to an Ops Dashboard, that URL has some funky URL encoding added which messes up the URL so that the survey can not be opened.
Here is the URL that is generated in the pop-up from the stand-alone web map (I have replaced the item id, lat, lon and firm name with generic values😞
arcgis-survey123://?itemID=<item-id>¢er=<lat>,<lon>&field:FIRMNAME=<firm-name>&field:METRO_FSCRP_ID=fscrp10000251&field:STREET=4130%20SW%20117TH%20AVE%20%23%20H
Here is the URL that is generated in the pop-up from the Ops Dashboard web map:
arcgis-survey123://?itemID=<item-id>%C2%A2er=<lat>,<lon>&field:FIRMNAME=<firm-name>&field:METRO_FSCRP_ID=fscrp10000251&field:STREET=4130%20SW%20117TH%20AVE%20%23%20H
Note that "¢er" in the URL generated in the stand-alone web map pop-up has been replaced by "%C2%A2er" in the URL in the Ops Dashboard map pop-up. The result is that an invalid itemId is created and Survey123 can't open the survey..... the Survey item ID contains a cent character.
