Operations dashboard not updating after deleting a record
933
07-25-2019 11:42 AM
JeffEisman
Operations Dashboard is not updating when features from a related table are deleted. The feature service is coming from Survey123. The tables reflect the correct data, but the numbers on the dashboard still show the same number as before the features were deleted.
DerekLaw
Esri Esteemed Contributor
Hi Jeff,
Did you set a refresh interval for the data layer in the web map?
Hope this helps,
JeffEisman
Thanks yes I did, It was just taking some time to update the dashboard after deleted records in ArcGIS pro.it ended up eventually correcting itself
