I am currently working with Operations Dashboard for ArcGIS deployed on a portal machine. The Machine is a physical machine accesses remotely through vpn and running on windows server 2012 R2. I made sure the .Net 4.5 is installed and running on the server. Yet every time I try to configure a widget after the webmap is loaded in the dashboard the app is not responding then crashing. Note that when installing Dashboards on Portal you have to point to a pfx ssl certificate and in this case I am using a self signed certificate. Also note that this is running on Enterprise 10.5.1 with no public facing IP, most of the websites are blocked since its a secured environment and finally I am working with Dashboard 10.3.4
Curious if anyone faced this before or have any idea what is going on? Peter Fitts DMarsh-esristaff
