Operation Dashboard
874
06-07-2019 11:06 AM
NusratFatema1
Does any body know why "layer not accessible " pops up when I try to add a layer in the dashboard I created. I added an excel table to my web map using 'add file from computer", but now I can not use the layer to the dashboard. Is it because it needs to be published as a feature  layer to be able to use in a dashboard? or something else. Is there any way I can add an excel table to my dashboard without publishing?
Thank You for you
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Nusrat,
> ... I added an excel table to my web map using 'add file from computer", but now I can not use the layer to the dashboard. Is it because it needs to be published as a feature  layer to be able to use in a dashboard?
Correct. Operations Dashboard works with feature and image layers.
Understand data sources—Operations Dashboard for ArcGIS | ArcGIS
This is not a supported workflow.
Hope this helps,
NusratFatema1
Thank So much . That helps.
