Have you further details in Event Viewer -> Windows Logs -> application ?for check if you have 4.5 you can run code kind this:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System;
using Microsoft.Win32;
namespace ConsoleApplication1
    class Program
        public static void Main()
            using (RegistryKey ndpKey = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, RegistryView.Registry32).OpenSubKey(@"SOFTWARE\Microsoft\NET Framework Setup\NDP\"))
                foreach (string versionKeyName in ndpKey.GetSubKeyNames())
                    if (versionKeyName.StartsWith("v"))
                        RegistryKey versionKey = ndpKey.OpenSubKey(versionKeyName);
                        string name = (string)versionKey.GetValue("Version", "");
                        string sp = versionKey.GetValue("SP", "").ToString();
                        string install = versionKey.GetValue("Install", "").ToString();
                        if (install == "") //no install info, ust be later
                            Console.WriteLine(versionKeyName + "  " + name);
                        else
                            if (sp != "" && install == "1")
                                Console.WriteLine(versionKeyName + "  " + name + "  SP" + sp);
                        if (name != "")
                            continue;
                        foreach (string subKeyName in versionKey.GetSubKeyNames())
                            RegistryKey subKey = versionKey.OpenSubKey(subKeyName);
                            name = (string)subKey.GetValue("Version", "");
                            if (name != "")
                                sp = subKey.GetValue("SP", "").ToString();
                            install = subKey.GetValue("Install", "").ToString();
                            else
                                    Console.WriteLine("  " + subKeyName + "  " + name + "  SP" + sp);
                                else if (install == "1")
                                    Console.WriteLine("  " + subKeyName + "  " + name);
