Logo icon is hidden on dashboard
2858
10
02-21-2023 09:08 AM
Arnaud_Leidgens
Hello everyone,
I've been using dashboards for a while now, without problems (ArcGIS Entreprise 11.0). I like to use default icons proposed by ESRI as logos for my thematic dashboards.
I'm not sure if this happenned after 11.0 update, but those logos do no display anymore on the header. Default icons are used, default color as well. I also tried different sizes and colors. It displays well when I configure it in the header settings, but it is transparent on the dashboard itself. Have you experienced such issue ? Thank you in advance.
Bec
This sounds similar to the issue I am having with my Attribute Selector icons within dashboard.  See the post I created a few weeks back:
https://community.esri.com/t5/arcgis-dashboards-questions/not-all-sidebar-selector-svg-icons-display...
Unfortunately, no one has replied to my post with any ideas as to why this is happening or solutions.
Arnaud_Leidgens
Indeed, it seems like the same issue. Are you working with ArcGIS Entreprise or AGOL ? Which version ?
I tried to clear cache, to create a new simple dashboard and display it with different browsers but no success so far.
Bec
ArcGIS Enterprise Version 10.7.1
Arnaud_Leidgens
Thanks. It doesn't seem to be linked to a specific version then. Are you able to correctly display svg icons in your dashboards headers ?
Bec
I have some selectors in my header and the SVG icons are working there for me.  I made some changes to my dashboard yesterday, as far as the layout goes, and now all my icons seem to be working just fine when I looked at it this morning.  I've opened it up a few times and in different browsers.  Not sure if there was just a glitch in the Dashboard software, but all is working now.
Arnaud_Leidgens
For information, I had a look with technical support. It's working with third-party custom png files, which is an acceptable workaround for now. A bug ticket was submitted.
Nicole_Ueberschär
Hello @Arnaud_Leidgens ! Do you happen to have the bug number for me so I can add my own case to it? Facing the same issue. Funnily, while editing I can see it but as soon as I leave edit mode it disappears.
Arnaud_Leidgens
Hello @Nicole_Ueberschär. Yes, it seems like the exact same issue. The number : BUG-000156134
Nicole_Ueberschär
FYI, for me it was not related with any update as we did the development of the dashboards in that portal and no updates were installed. It "just happened" suddenly. I cannot tell though when as I didn't pay attention to the logo when looking at the dashboards. Only when I took screenshots today is when I realized the issue.
