Since the latest update to Dashboards, I have noticed that lists and category selectors no longer successfully filter the pop-ups of map layers.
For example, I have a map with a polygon layer - polygons have an attribute of survey 1, 2 or 3. Some of the polygons are overlapping. I want to create a list that allows the user to filter the polygons by survey. When I do this be setting a filter action from the source list to the polygon layer on the map, the polygons themselves filter successfully - ie if I click Survey 1, I only see Survey 1 polygons on the map. However, I still see pop-ups from the other surveys. If two polygons from survey 1 and 2 were overlapping, I only see the survey 1 polygon upon making the selection in the list, yet there are two stacked pop-ups (one for each survey).
This did not use to happen prior to the latest update to Dashboards.
