Is there a widget that sums features across all featurelayers in the map?
2436
02-23-2016 09:22 AM
NiravShah
I have what I thought would be a simple requirement: sum up the features in the map across all featurelayers.
I see that I'm able to have a statistics widget that gives me a count for all features in a featureservice.
It would be great if there were a widget where I'd configure it with a list of featurelayers in the map and have it display a number reflecting the total across all those feature services.
If there is no such widget, is there a sample custom widget that might be a good starting point for development?
Thanks!
ChristopherOlsen
Hi Nirav,
You can limit the results you get on the summary widget to the map extent if you didn't want all features. Jake Skinner​ posted a walk through on setting that up here: Limit Widget Results to Current Map Extent
But this will only work for one layer at a time.  You would need to use a custom built widget to get those results across all layers.
Chris
