Indicator numbers cutting off
5377
16
10-23-2020 08:44 AM
MikeSchonlau
Is anyone else seeing this issue? I guess the simple solution is to shrink the font size, but I thought the font would auto-adjust to it's window??
indicator cutoff
TBWI
Has anyone found a resolution to this issue? We are encountering it as well on our webpage. It cuts off the end and bottom of the indicator text upon initial webpage loading and resolves with refreshing.
IonSola_Torralba
Almost four years later this is still unresolved. Even if after refreshing the page the problem dissappears it is a HUGE aesthetic issue for users when they access the dashboard the first time. This should be a priority
EmilyAust1
Seriously. What is going on, ESRI?
RoryMacGregor
We also have this issue on all of our dashboards. It looks very amateur.
MarlboroughDistrict_Council
All our dashboards do this too. Almost five years since this post was started and still no update ESRI?
KathrynWesson
I brought it up with @DavidNyenhuis1 at the Esri UC this past July. The devs are aware of the issue, and have tried multiple times to fix it, but it continues to revert back to doing this for some reason. They can't figure it out.
Thanks. Good to know ESRI are aware and have looked into this. Hopefully they find a fix one day!
