Include sum and average in bar chart using data expression/arcade
1320
03-08-2024 06:44 AM
dwold
I am trying to write a data expression that finds the count of that field. Then calculates the average of a field (filter/selection dependent) and use that in a bar chart along with the sum of another field.
In the picture below, I am trying to get the Target Goal to be 12 (24/2 records) while the Target Value (14) is the sum of 2 values.
var fs = FeatureSetByPortalItem(
  Portal("https://www.arcgis.com/"),
  "384158f2ebe34f8ba8b0b39dfe5f5af5",
  0,
    'Jurisdiction',
    'core_capability',
    'target',
    'target_goal',
    'target_value_final'],
  false
var tar_goal = $feature.target_goal
var tar_final = Filter(fs, "target_goal = @tar_goal")
//find the total count of tar_final
var tar_count =  Count(tar_final)
//find sum of target_goal
var goal_sum = Sum($feature, tar_goal)
//Divide the sum of target_goal by target goal count
var targets = goal_sum/tar_count
return targets
@JohannesLindner
jcarlson
Remember, you need to return a FeatureSet from a Data Expression. Also, in a Data Expression, there is no global $feature.
You can get the count and sum both out of a GroupBy function, and even do some derived values involving multiple fields.
The tricky part is "filter/selection dependent". Aggregating in a Data Expression is going to break any kind of per-feature identification in the data.
Are you wanting the "goal" value to come from the selected feature? I don't believe there's a way to pipe values into a data expression from the dashboard's interactivity.
- Josh Carlson
Kendall County GIS
dwold
Are you wanting the "goal" value to come from the selected feature?  - yes but it isn't a deal breaker for my case. I am trying to find the average of target_goal and use that as a field in my bar chart. If I do group by would it look something like this? Perhaps I am doing this all wrong.
  0,
    'Jurisdiction',
    'core_capability',
    'target',
    'target_goal',
  false
var goal_group = GroupBy(fs, 'target_goal', {name: 'Goal', statistic: 'Count'})
var value_group = GroupBy(fs, 'target_value_final', {name: 'Goal', statistic: 'Sum'})
var end_value = value_group / goal_group
return end_value
