How can I replicate my operations dashboard and have it linked to new data files without having to re-configure all the dependencies?
After copying the Dashboard, use the "I want to..." dropdown and select "View an Item's JSON".
In the Data portion, you can edit the itemId property to point to the new data.
I would give the AGO Assistant tool a try: ArcGIS Online Assistant
You can point to your Dashboard item and then create a copy of it.
You could also do this with all of the dependencies and then edit as you see fit.
Thanks for the quick response. However, if I just copy the dashboard the pointers will still point to the original data files. I need a way to edit the dashboard so they point to new files.
Hi David,
Please vote for the enhancement on the ArcGIS Ideas site, Operation dashboard - Add the ability to save as a template
Hope this helps,
This looks like what I need, but where do I find the “I want to …” dropdown?
Thanks. Using AGO Assist to edit JSON code provide a whole new dimension to modifying dashboards.
