How do you clean up unanswered survey questions in a dashboard popup.
2373
06-05-2020 06:08 AM
GarrettBlevins
I have a form on Survey123 which collects point data along with other information. This data is put into a webmap which is displayed on a dashboard. When you click on the point in the map the popup shows all possible fields on the form. I would like to clean it up so that only the fields that were answered get displayed.
DonShawEsri
Hi Garrett, this kind of behavior may be possible through the web map via an Arcade expression.
Check out these posts
 https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2017/07/18/conditional-field-disp...
Can i eliminate empty values using arcade in my pop up?
There are also some introductory videos for Arcade if you are interested
Pump Up Your Pop-Ups with Arcade Expressions - YouTube
Getting to Know Arcade - YouTube
GarrettBlevins
Thank you!
I will admit I have not written an Arcade Expression before.
I am running into an issue where I have gotten it to leave out null attributes but when there is data it now only lists the data and not the label in the popup. Here is what I am running into. The Numbers Below should say-"Reporters Phone Number"
My expression is:
IIF(isempty($feature["field_9"]),"",$feature["field_9"])
Table to display is:
Any help you can provide is helpful. Thank you
DonShawEsri
Try this in your second table row with expression/expr1:
      <td><b> Reporters Phone Number: </b> {expression/expr1}</td>
GarrettBlevins
I thought of that but then it puts it on every popup when the goal is to have it show up only if that point has that field.
CameronAmrine1
Hey Garrett,
Here is some arcade you can use. It will remove any fields that are null/empty. Additionally, the order in which you declare the fields in the script will be how they show up in the popup.
#Create dictionary of fields. Text within single quotes is the desired field alias
var fields = Dictionary('Field Name 1',$feature.Fieldname1,
 'Field Name 2',$feature.Fieldname2,
 'Field Name 3',$feature.Fieldname3);
#Populate dictionary with fields from above
var fields = [Dictionary('fieldName', 'Field Name 1', 'fieldValue', $feature.Fieldname1), Dictionary('fieldName', 'FieldName2', 'fieldValue', $feature.Fieldname2), Dictionary('fieldName', 'Field Name 3', 'fieldValue', $feature.Fieldname3)];
var popup = '';
#Remove null/empty fields
for(var f in fields){
if (IsNan(fields[f]['fieldValue'])== false && IsEmpty(fields[f]['fieldValue']) == false){
 popup += Concatenate([fields[f]['fieldName'], ':', ' ', fields[f]['fieldValue'], '\n'], '');
return popup;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Just insert the expression into your popup as a custom popup. If there are a ton of fields, it can be tedious but it works!
If its being entered into a Details Element within a dashboard you can also add html tags to line 15 to make text bold or add color.
Just a note: This does not change the actual data itself in any way. It's just forming the popup in memory and displaying the data in a different way visually.
