How can I configure the Arcade expression for Operations Dashboard to dynamically change data in widgets when map extent changes?
6012
10
01-04-2022 11:06 AM
Norchevskyi
I have the Arcade Expression (that was described here:ArcGIS Operations Dashboard Arcade Join Table )  for the Indicator widget, that perform a join operation between a feature layer and a feature table, I applied the rule "When map extent changes" in Map actions for the Indicator widget. But the Widget doesn't display the data, that is empty.
Is it possible to customize the Arcade expression so that the widget dynamically displays data from the current extent?
Thank you,
Roman
ScoutStanley
For my project with using survey123 results, I found recreating within experience builder was the way to get it to work. Below is link to post I created. Hopefully that helps out some!
https://community.esri.com/t5/arcgis-dashboards-questions/how-do-you-connect-feature-set-dictionary-...
