Here's one I use to concatenate fields. It uses GroupBy to get the required fields and counts, then creates a new featureset with the concatenated fields.
My original dataset has the field Strat_Num, which is a unique combination of Habitat, Depth, Subregion, and Admin.
I wanted to group by Stratum Number, concatenate the other values, and get their count.
This is the code I came up with
var fs = FeatureSetByPortalItem(
Portal("https://www.arcgis.com/"),
"itemId",
var grouped = GroupBy(
fs,
"Strat_Num",
{ name: "Habitat", expression: "Habitat", statistic: "Max" },
{ name: "Depth", expression: "Depth", statistic: "Max" },
{ name: "SUBREGION", expression: "SUBREGION", statistic: "Max" },
{ name: "ADMIN", expression: "ADMIN", statistic: "Max" },
{ name: "Count", expression: "1", statistic: "Count" }
var features = [];
for (var i of grouped) {
Push(
features,
attributes:
Number: i.Strat_num,
Stratum: `${i.Habitat} ${i.Depth} ${i.SUBREGION} ${i.Admin}`,
Count: i.Count
return FeatureSet(
fields: [
{ name: "Number", type: "esriFieldTypeInteger" },
{ name: "Stratum", type: "esriFieldTypeString" },
{ name: "Count", type: "esriFieldTypeInteger" }
features: features
);which gives me this table
