'Gauge' widget shows all decimals
11335
11
09-23-2014 04:55 AM
AndreasEspersen
I have an annoying problem working with Gauge Widget. The problem is that the gauge widget is showing lots of decimals as show below.
The web map is set to only show two decimals but the Gauge Widget is not honouring the setting as shown below:
A workaroud is rounding the values in the database but it would be nice if the cauge was working like the bar chart widget.
Showing the same data in the bar chart the decimals are shown as expected.
Tags (3)
TifPun
Hi Annina,
Hope everything goes well with you. With the latest release of our app, you will now be able to configure the display format/pattern of numbers in the legend and hover texts of your pie chart. In your case, if you want to round the decimal number, you can input "#" into the Pattern box. If you want, you can control the number of decimal places by adding more "#" e.g. "#.#" for one decimal place, "#.##" for two decimal places, and so on.
If you need any further help, please let us know.
Tif
(As shown below, you can find the setting at the bottom of the Chart tab.)
JessicaGooch1
Hi all,
I am having a similar issue on my serial chart. I have saved my data to show only one decimal place in the map, but the serial chart is showing 5 decimal places on the category axis...
Any thoughts?
