Hello,
I am trying to build a new data expression in a serial chart within my ArcGIS Dashboard app using FeatureSetByPortalItem().
I can create one connecting to my AGOL account, however I don't seem to be able to create one connecting to my local Enterprise Portal account. When I try I get the following error message:
Execution Error:Item does not exist or is inaccessible.
From what I can read via: https://developers.arcgis.com/arcade/guide/types/#portal
I should be able to connect to a service via its service ID. The service exists, but I am not able to connect to it. Right now the service is shared with a Beta Testing group within our Portal.
Is there a chance my share settings are blocking it? I am an admin and member of said group. I have tried both the default 'www.arcgis.com' and the URL for my Enterprise Portal.
Any ideas? Thanks
var p = Portal('https://www.arcgis.com');
var features = FeatureSetByPortalItem(
p,
'xxxxxxxxxxxx',
0,
false
Count(features);
The URL must be the portal's URL, i.e., https://maps.co.kendall.il.us/portal would be mine.
If you're trying to access a service that is not shared publicly, it should prompt you to log in. Where are you running the expression, AGOL or your portal? Is the layer shared?
Thanks.
I am running the expression via an ArcGIS Dashboard on our Enterprise Portal.
The service in question is shared within our organization. I am an admin for the organization as well.
I updated the script as you have shown and now it seems to be working. Thanks!
So the next step is how do I go about intersecting 2 services and creating a new summarized feature set to capture the number of point features within intersecting polygons?
Spatially intersecting two layers works the same, regardless of where the two layers come from. Here's a rough idea of what this would look like, though you'll need to make some adjustments.
var p1 = Portal('portal-url')
var p2 = Portal('agol-url')
// your portal fs; i'm assuming that this is the polygon layer
var fs1 = FeatureSetByPortalItem(
p1,
'itemid',
0,false
['objectid'],
true
// your agol fs
var fs2 = FeatureSetByPortalItem(
p2,
'itemid',
0,
['objectid'],
false
// output dict
var out_dict = {
fields: [
{name: 'polygon_id', type: 'esriFieldTypeString'},
{name: 'point_count', type: 'esriFieldTypeInteger'}
geometryType: '',
features: []
// loop through polygons, get points
for (var f in fs1) {
var xs_pts = Intersects(f, fs2)
Push(
out_dict['features'],
attributes: {
polygon_id: f['objectid'],
point_count: Count(xs_pts)
return FeatureSet(Text(out_dict))
Thanks again for your help on this.
I updated my script to the following and while the returned numbers seemed valid when testing, the return lacks information in the SIZE and RISKCNT fields.
What am I doing wrong?
var p = Portal('https://maps.xxxxx.com/portal/')
var sql = "(DATE > CURRENT_DATE - 7)"
var sqlST = "(STATE = 'CO')"
// the polygon layer
var fsHail = FeatureSetByPortalItem(p,
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0, ['label', 'SIZE', 'DATE_TEXT'], true
var fHail = Filter(fsHail, sql);
// the pts layer
var fsInforce = FeatureSetByPortalItem(p,
0, ['PolicyNumber', 'LocationID', 'LOB', 'TIV', 'RiskCount'], false
var fInforce = Filter(fsInforce, sqlST);
/*Count(fInforce);*/
// output dict
var out_dict = {
fields: [
{name:'SIZE', type:'esriFieldTypeInteger'},
{name:'RISKCNT', type:'esriFieldTypeInteger'}
geometryType: '',
features:[]
for (var f in fHail) {
var xs_pts = Intersects(f, fInforce)
Push(
attributes: [
RISKCNT: Count(xs_pts)
attributes is a dict, not an array, and I realize I had that wrong in my expression.
It should be:
attributes: {
}I will update my post accordingly.
