Distinct count issue using list element
1374
01-04-2022 09:55 PM
SayedWali
Using the List Element I am taking multiple layers and out of that, I am going to count the number of reportIDs per Province to know how many monitoring visits were carried out in each province. But looks like it doesn't count properly and the province is not listed uniquely. With my very light knowledge of Arcade I can't figure it out, any help will be appreciated:
var portal = Portal('https://www.arcgis.com/');
// Group by province
// Count report IDs
var HMAFAR = GroupBy(
FeatureSetByPortalItem(portal,'56db417ebbc541bcbb6ccf9c49524cc9',0,['*'],false),
['province'],
{ name: 'FAR_ID', expression: 'rpt_id', statistic: 'COUNT' },
var HMAPDIA = GroupBy(
FeatureSetByPortalItem(portal,'cd991db8686d4d0b8c9a6c0e910f03ab',0,['*'],false),
['field_8'],
{ name: 'PDIA_ID', expression: 'field_1', statistic: 'COUNT' },
var MRE = GroupBy(
FeatureSetByPortalItem(portal,'3e63815f693a4d0888209d58ebe7fe8b',0,['*'],false),
['field_8'],
[{ name: 'MRE_ID', expression: 'field_1', statistic: 'COUNT' },
var NTS = GroupBy(
FeatureSetByPortalItem(portal,'30b595fc7ef64bb596bebcbbffb68db6',0,['*'],false),
['province'],
{ name: 'NTS_ID', expression: 'repid', statistic: 'COUNT' },
var FHMAML = GroupBy(
FeatureSetByPortalItem(portal,'4861c1d8d407434193a012b504b69b36',0,['*'],false),
['field_8'],
{ name: 'HMAML_ID', expression: 'field_1', statistic: 'COUNT' },
var HMAML = filter(FHMAML, "ml_type = 'HMA ML'");
var VA = GroupBy(
FeatureSetByPortalItem(portal,'fbaf2ac4f8bc413c8770f7aaf4e77c4d',0,['*'],false),
['province'],
{ name: 'VA_ID', expression: 'rpt_id', statistic: 'COUNT' },
var layersDict = {
fields: [
{ name: 'Reports_Type', type: 'esriFieldTypeString' },
{ name: 'count_of_ids', type: 'esriFieldTypeInteger' },
{ name: 'provinces', type: 'esriFieldTypeString'},
geometryType: '',
features: [],
// Loop through each of the six FeatureSets and store attributes into a combined dictionary.
var i = 0;
for (var f in HMAFAR) {
layersDict.features[i] = {
attributes: {
Reports_Type: 'HMAFAR',
count_of_ids: sum(f['FAR_ID']),
provinces: f['province'],
i++;
for (var p in HMAPDIA) {
attributes: {
Reports_Type: 'HMAPDIA',
count_of_ids: sum(p['PDIA_ID']),
provinces: p['field_8'],
i++;
for (var m in MRE) {
attributes: {
Reports_Type: 'MRE',
count_of_ids: sum(m['MRE_ID']),
provinces: m['field_8'],
i++;
for (var n in NTS) {
attributes: {
Reports_Type: 'NTS',
count_of_ids: sum(n['NTS_ID']),
provinces: n['province'],
i++;
for (var ml in HMAML) {
attributes: {
Reports_Type: 'HMAML',
count_of_ids: sum(ml['HMAML_ID']),
provinces: ml['field_8'],
i++;
for (var v in VA) {
attributes: {
Reports_Type: 'VA',
count_of_ids: sum(v['VA_ID']),
provinces: v['province'],
i++;
// Return dictionary
return FeatureSet(Text(layersDict));
JohannesLindner
You have to do a final GroupBy on layersDict to get the sum of all counts.
// do a final GroupBy to add all reports in each province
var layers_fs = FeatureSet(Text(layersDict))
return GroupBy(
    layers_fs,
    ['provinces'],
    {name: 'TotalReportCount', expression: 'count_of_ids', statistic: 'SUM'}
Have a great day!
Johannes
JohannesLindner
return GroupBy(
    layers_fs,
    ['provinces'],
Have a great day!
Johannes
SayedWali
Thank you! worked out
