data expression using $map in a FeatureSetbyName (or ID) shows as 'undefined' variable
1991
06-28-2024 07:08 AM
clt_cabq
I'm writing a data expression and can make the FeatureSetByPortalItem function work, but when trying to use FeatureSetbyName the statement shows an error where $map is 'undefined'. Its unclear to me why either of those two options should fail? I thought they were both functional for data expressions, but perhaps not?
KenBuja
MVP Esteemed Contributor
Dashboards don't have the $map profile variable.
KenBuja
clt_cabq
Welp, that is why then. Its confusing because the documentation for those functions indicate they are for working with dashboards. thanks @KenBuja.
KenBuja
Yes, that is confusing. The documentation should point to the Dashboard group instead of Databoard data, since other Dashboard profiles do give access to the $datapoint profile variable, which those two functions can utilize.
