Data Expression returns blank from DateDiff method
1497
12-24-2024 02:22 PM
AshneyDaniel
I'm creating an Arcade expression to feed a dashboard list. The expression groups on an ID to find the earliest date, then I want to find the difference between that date and todays date but DateDiff is returning blanks. I know that date formatting is picky in arcade. Its probably a formatting issue but I cannot figure it out.
Here is the code, which successfully returns a featureSet with a 'scheduled_date' and 'today_date' but 'days_remaining' is empty. I've exclude the connection steps since I know I'm successfully pulling in scheduled_date from the source.
// Group on area_id and get aggregate values
var groupedRequests = GroupBy(hydrant_requests, ['area_id'],
 {name: 'ScheduledDate', expression: 'schedule_date', statistic: 'MIN'}
var resultFeatures = [];
var feat
var today_date = Today()
// create a feature array which combines the grouped values + a calced field
for (var record in groupedRequests)
      feat = {
        attributes:
                 'area_id': record['area_id'],
                 'scheduled_date': Number(record['ScheduledDate']),
                 'today_date' : Number(today_date),
                 'days_remaining': DateDiff(Number(record['ScheduledDate']), Number(today_date), 'days')
      // Add each feat result to the resultFeatures array
      Push(resultFeatures, feat);
// Create a dictionary from the feature array
var myDict  = {
                'fields': [
                    { name: 'area_id', type: 'esriFieldTypeString' },
                    { name: 'scheduled_date', type: 'esriFieldTypeDate' },
                    { name: 'today_date', type: 'esriFieldTypeDate'},
                    { name: 'days_remaining', type: 'esriFieldTypeInteger'}
                'geometryType': '',
                'features': resultFeatures
// Convert dictionary to feature set which can be used in the widget
var fs_dict = FeatureSet(Text(myDict));
return fs_dict;
Result:
Any ideas appreciated. Thanks!
jcarlson
Wrapping dates in Number() is a good idea for Data Expressions, but the function DateDiff should be given two dates. The way you have it written, you're giving it two numbers. Try just taking the number functions out.
'days_remaining': DateDiff(record['ScheduledDate'], today_date, 'days')
- Josh Carlson
Kendall County GIS
